Pelle Hydraulique liebherr 984R 1:14
- TESSEN
- Pays : E
- A remercié : 6 fois
- A été remercié : 8 fois
Hi,in the first place and after the presentation of myself in the correct section, sorry to write in english, if anyone want to write can do it in french, ok, the important part, the pictures
in those post i'll show the works of years working, is tired but it´s funny
i have not finish the 3D model yet but i want to machining something! ok, i´ll post a lot of photo and video,as note, and all my major machines are DIY
ok, here we go!
the first piece is a link of the chain
i have to machining 196 links, a preview model
a video of the machining (right link)
[bbvideo=853,480]https://youtu.be/7DmqKonu2IE[/bbvideo]
[bbvideo=853,480]https://youtu.be/7Rv3OzudaCM[/bbvideo]
and the left link
[bbvideo=853,480]https://youtu.be/P0JbwqnjaF8[/bbvideo]
the traction wheel:
i use a cycloid gear inside the wheel cube with a relation on 1:100 and i turn this shaft using a timing pulley with a 1:6 relation --> final relation 1:600
sectional cut
videos
[bbvideo=560,315]https://youtu.be/vtx9vAy3h9I[/bbvideo]
[bbvideo=560,315]https://youtu.be/jrk4c-XzaZA[/bbvideo]
ok, this is the current status , i need to make the pads for the chain, at the first place i thought to machining it, but i have to rotate them in the mill many times, too boring, i had to learn another technique, lost wax casting
the first cast (bronze)
regards
ok, here we go!
and the left link
the traction wheel:
sectional cut
videos
regards
Modifié en dernier par TESSEN le 17 févr. 2018, 20:13, modifié 3 fois.
- A remercié : 55 fois
- A été remercié : 237 fois
Re: Pelle Hydraulique liebherr 984R 1:14
Really nice work, the parts are beautiful
You make them with a CNC?
- TESSEN
- Pays : E
Hi cc38150, thanks, yes, the most parts are made with a self made cnc machinery
more photos
(obviously these are not the final screws)
the second cast (brass)
the third cast (brass)
the third casting was better, i made the pads that i needed and i did a test casting, to saw that this technique is able
the wax test cast
the final cast
my pads cast
more photos
the wax test cast
the final cast
my pads cast
Modifié en dernier par TESSEN le 20 nov. 2017, 10:38, modifié 1 fois.
- MAILLOY
- Numéro de département : 974
- A remercié : 337 fois
- A été remercié : 171 fois
nice, goob job love this
- ZipZip
- Numéro de département : 17
- A remercié : 9 fois
- A été remercié : 7 fois
Great job
John deere 9530 + Remorque Joskin Blocher Vendu
Liebherr L574 - 7,2kg Vendu
BELL B50D Fumotec
Chargeur 870K
BELL B50D Fumotec
Chargeur 870K
- TESSEN
- Pays : E
thanks guys!
Well, these are the most important pieces, now it make a dotted and drill (which has no mystery), one thing that if it could be funny / curious, are the nuts with hex screws that hold the pads to the chain, finally i did it with my cnc router, the pieces were made in brass, nuts are threaded to M2 and measure 3x3mm, totaling 405 nuts, machined with a 1.5mm drill (the champion of end mills)
a little video of the machining
[bbvideo=853,480]https://youtu.be/NHkC2UHnynI[/bbvideo]
and finally .. I could assemble the track
more photos, this is the time of the hubcaps for the traction wheel, made of aluminum
the master piece is made in 2 pieces, one milling and the other are made using laser engraving
after that, both are join
the mold and the wax copies
the result of the casting
salu2!
salu2!
Modifié en dernier par TESSEN le 17 févr. 2018, 20:15, modifié 2 fois.
- louloubenz
- Numéro de département : 5
- A remercié : 16 fois
- A été remercié : 53 fois
- TESSEN
- Pays : E
thanks for comments
more advanced, the lower structure, all stainless steel 3 mm and 1.5mm
the following photos correspond to the lost wax casting of pieces for support and guides rollers on tracks
and a pair of test of my future valves (for the moment, prototype)
https://www.youtube.com/watch?v=ACX_2GJdTNQ
https://www.youtube.com/watch?v=-big2h1tJiE
salu2! (best regards)
Modifié en dernier par TESSEN le 20 nov. 2017, 10:40, modifié 1 fois.
- Goliath
- A remercié : 789 fois
- A été remercié : 285 fois
Good job!!!
- CATER PILLAR
- A remercié : 17 fois
- A été remercié : 27 fois
- crocblanc01
- Numéro de département : 57
Very good job
Can you give us the weight of the base
Envoyé de mon PLK-L01 en utilisant Tapatalk
- TESSEN
- Pays : E
thanks, i don't know what part you refer, but all the lower superstructure weighs about 15 Kg
the last photos and one test video
[bbvideo=853,480]https://youtu.be/ZSXQkJDTfbQ[/bbvideo]
regards
regards
Modifié en dernier par TESSEN le 17 févr. 2018, 20:16, modifié 2 fois.
