je suis a la recherche de documentations et de photos sur le white 666 de la seconde guerre mondiale pour un future projet, si vous avet des blogs ou sites je suis preneur
Danish Army Specific: Used in the artillery as prime mover for 90 mm gun M/50, 155 mm gun M/52 and 203 mm howitzer M/55. Also used by the engineers typically with a Rogers M9 trailer as Heavy Equipment Tractor (HET). Here shown with a Caterpillar D7C dozer on the trailer.
Some vehicles delivered were manufactured by Corbitt (27 kb). Both types were delivered with open and closed cab.
Historical: Designed for the US Coast Artillery and produced from 1941 until 1945 to a common specification by White and Corbitt. A soft-top version (shown) was available from 1942. In addition to the cargo/prime mover trucks there were several derivatives.
Co-producers of certain types were Brockway, FWD and Ward LaFrance. Grand total, all types, was over 21.000.
Length: 7.35 m (286 inches).
Width: 2.45 m (95 inches).
Height: 3.05 m (118 inches).
Weight: 16.500 kg (36.300 lb.).
Engine: 6-cylinder Hercules HXD, 14.000 cm3 (855 cubic inches) displacement, liquid cooled.
Horsepower: 205 at 2.150 rpm.
Transmission: 4-speed gearbox.
Transfer case: 2-speed.
Electrical system: 6 volt (12 volt starter), positive ground.
Brakes: Air (Bendix-Westinghouse).
Tyres: 10.00 - 22.
Fording depth:
without preparation: 0.6 m (24 inches).
with deep water fording kit: N/A.
Fuel type: Petrol.
Fuel capacity: 300 liter (66 gallons).
Range: 480 km (300 miles).
Crew: 1 + 1.
Additional: Winch capacity: 2.700 kg. Earlier models had a 12.7 liter 165 hp engine.
